[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 136: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 138: array_unique() expects parameter 1 to be array, null given [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 141: Invalid argument supplied for foreach() [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 136: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 138: array_unique() expects parameter 1 to be array, null given [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 141: Invalid argument supplied for foreach() [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 136: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 138: array_unique() expects parameter 1 to be array, null given [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 141: Invalid argument supplied for foreach() [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 136: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 138: array_unique() expects parameter 1 to be array, null given [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 141: Invalid argument supplied for foreach() [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 136: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 138: array_unique() expects parameter 1 to be array, null given [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 141: Invalid argument supplied for foreach() [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 136: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 138: array_unique() expects parameter 1 to be array, null given [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 141: Invalid argument supplied for foreach() [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 136: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 138: array_unique() expects parameter 1 to be array, null given [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 141: Invalid argument supplied for foreach() [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 136: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 138: array_unique() expects parameter 1 to be array, null given [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_reimg.php on line 141: Invalid argument supplied for foreach() W124Club.nl • klok en binnenverlichting : Techniek
ik heb geen radio nu raak ik met plus de aarde en pats geen klok en binnenverlichting motor zekeringkast een zekering vernieuwd maar nog geen binnenlicht en klok
Re: klok en binnenverlichting
Geplaatst: zo nov 06, 2011 10:09 pm
door EvdV
Dit lijkt op mijn probleem. Zie "probleem binnenverlichting en klokje".
Doet het klokje en de binnenverlichting het wel als de deuren dicht zijn en het contact op accessoirestand?
Bij mij was het de onderste deurschakelaar welke niet goed werkte.
Eli
Geplaatst: ma nov 07, 2011 7:56 am
door ron8762
ik ga vandaag kijken hoe of wat als ik alarmlichten aan zet doet knipperlicht links en rechs het niet zet ik alarmknipperlicht uit doet l en r knipperlicht het wel dit gebeurde zins ik kortsluiting maakte met plus deaad achter radio zo doet binnenverlichting het niet en klok ook niet ???????
Geplaatst: za nov 12, 2011 11:49 am
door EvdV
Is het probleem al opgelost? Zo ja, hoe?
Eli
Geplaatst: za nov 12, 2011 2:56 pm
door Mafkees
Kijk eens naar de K1 zekering, achter je accu. (zie foto)
Geplaatst: za nov 12, 2011 9:53 pm
door ron8762
hoi jes jes jes klok en binnen verlichting deden het niet door zekering was niet kapot maar zwart op puntje ik andere in gezet en jes jes klok en binnen licht weer oke
